what caused this??
Old Nov 24, 2002 | 06:12 AM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
what caused this??
Last time at the track,about 10` off the starting line,BANG.(Banged so hard my airbag flew out)Push it off the track,discover the front u-joint in pieces,the tailshaft housing snapped off and the bellhousing broke completely in two. As a result,the weight of the trans bent the input shaft and damaged the pump.My trans guy says an upward motion caused it to break in this fashion.If that`s the case I think I would see the crossmember bent upwards too,but its not.I can understand the tailshaft housing breaking due to the u-joint but not the case.Anyway,it`s fixed,and now has an Ultrabell from JW.Any thoughts as to what happened? All bolts were tight and the case wasn`t cracked before
Old Nov 24, 2002 | 07:23 AM
ede's Avatar
ede
my guess would be the torque arm
Old Nov 24, 2002 | 11:38 AM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
Don`t have one!
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
