old Auto wiring in the center console.
Old Nov 25, 2002 | 04:18 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
what do i do with the wires on the gear select lever from when the auto was in my car (i now have a t56)? there are maybe (just guessing, car is not with me right now) 8-10 wires that i dont know what to do with, I cant just cut them because the lever has to be where it would be in park on the auto, otherwise it wont start. what should i do with all the wires?
also, with the speedo hookup, what EXACTLY do i need to make it work? got a link to where i can buy it?
my car is an 89 IROC with 350 TPI
Old Nov 25, 2002 | 05:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
To fix the neutral safety switch problem, look under the dash near the brake pedal, and find a connecot with a large yellow and a large purple wire in it. Unplug it, and either plug it into the clutch safety switch on your new set of pedals, or make a jumper for it out of a short piece of #12 wire with 2 male slide terminals.
2 of the other wires are for the back-up lights. IIRC there's a switch on the T-56 to hook those to so that they'll work.
Good luck on the speedo.... Jags That Run used to make the thing we need, but I hear has discontinued it. Let us know when you find a solution.
Don't just cut wires, they're there for a reason, understand them and use them properly, or remove them entirely. Don't sodomize your car that way. It gives all of us a bad reputation as owners of these cars when people see them around just hacked to death like that.
Old Nov 25, 2002 | 09:55 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
thanks for the response!
im not going to just cut them. i dont like to "leave things hanging" so to speak. if something gets done on my car, it gets done right. when i said cut, i meant trace them to where they go and cut them (meaning remove them) but i need to hook up my reverse lights and the clutch's neutral safety switch.
so were screwed with the speedo?
thanks again.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Firebird sweden
Aug 16, 2015 05:02 PM
mx127
Aug 10, 2015 08:13 AM
