Disconnecting Driveshaft
Old Nov 29, 2002 | 09:57 AM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
My transmission is toast and I can't roll my car backward, so I'm disconnecting the driveshaft. I have the caps off the rear pinion flange. It looks like the only way to proceed is to slide the driveshaft forward so I can get the u-joint out, but I can't get it to go. It is a litle rusty under there. How do I get the u-joint out?
Old Nov 29, 2002 | 10:23 AM
Momar's Avatar
If you have the driveshaft unbolted from the rear end, you will probably just have to pry/pound it loose from the rear end of the car. If it hasnt been out in a long time they can stick in there pretty good.
Ben
Old Nov 29, 2002 | 10:46 AM
87kevroc's Avatar
Yeah, I just had to pry between the pinion flang and u-joint and eventually I got it. Thanks.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
