86 open wheel 3.42 to 4.11 posi low budget
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I am searching but on the web all you find are $2,000 parts, not in my range. are used parts possiable. what parts am I looking for???
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i think youll be looking for aftermarket since there are no 7.5" axles with 4.11 from factory that im aware of..
unles you can find a way to get a Chevy Luv axle under your car, theyre 4.11 from factory, otherwise 3.73 is lowest i can think of in the small 10 bolts... maybe you can find someone with 4.11 7.5" gearset for sale for decent deal ??
good luck
good luck
Car: 4
Engine: 6
Transmission: 5
Can't get a 4.11 for these AFAIK, but maybe you could settle for a 4.10?
http://www.drivetrainspecialists.com...=28&cat=GM+7.5
About 1/3 of the way down the page, the GM ones for $187.50... they have others as well.... obviously you'll need a posi carrier as well
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
GM did put 4.11 gears in 7.5's, The factory set I have came out of an s10. I had another set that came out of a friends 83 v6 truck. So they are out there just finding them can be the problem.
Later
Spud
Later
Spud
My 88 S10 has a 4.10 limited slip rear. Just about any 82-88 4 cylinder S10 will have either 3.73 or 4.10 gears factory, with the 26 spline axles. All 4wd S10/Blazers came with limited slip rears. Look around in the junkyard for the right combo.
ambainb
Apr 25, 2016 09:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
