Which size gear housing ? 7.75 or 7.62?...
Old Dec 12, 2002 | 07:18 PM
giff's Avatar
Car: 91 G92 Formula, 35k original miles and owner
Transmission: 5 speed
I'm changing my leaking pinon (sp?) seal and have been told there was two different size rear ends used for 91 - so there are two different seals.
i've got the 3.42 (GU6) with the locking diff (G80) Are the locking diff's all the larger 7.75 for 91? What's the easiest way to check? Will the RPO info on the inside of the console tell me?
giff
Old Dec 12, 2002 | 08:20 PM
ede's Avatar
ede
7.5 and 7.62 are 10 bolt rears, the other is either a 9 bolt or dana 44
Old Dec 12, 2002 | 09:10 PM
82camaro's Avatar
Car: 82 camaro SC
Count the bolts on the cover. 10 bolts is a 7.625, 9 bolts is a 7.75--both could have posi. However, 3.42's are a 10 bolt gear ratio--7.625 is the one you want.
Old Dec 12, 2002 | 10:50 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
7.625 ??? i thought we had 7.5 ?? huh ?
Old Dec 13, 2002 | 06:21 AM
ede's Avatar
ede
7.62 and 7.5 are the same rears for some reason gm decided to use two names for the same piece.
toronto formula
Nov 10, 2015 06:17 AM
gta90
Sep 15, 2015 04:00 PM
madsv1000
Aug 20, 2015 06:45 AM
knight72
Aug 10, 2015 09:32 PM
