Pressure regulator valve
Old Dec 12, 2002 | 08:14 PM
MrHllywd07's Avatar
Does anyone know a procedure for removing the pressure regulator valve cap in a 700r4? I have mine stuck in the hole without the valve in place, or the sping. It is tight in place and dont know how to get it out. I was installing a shift kit and got myself into this mess.
85 TA, new 305, new 700r4, K&N
Old Dec 12, 2002 | 10:27 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
As long as the c clip is out the valve should fall down, if not get a screw driver and wiggle the valve a little or tap the case. Sounds like a B&M install to me if so DO NOT USE the line bias blocker rod or street strip accumulator spacers.
Old Dec 13, 2002 | 06:18 AM
MrHllywd07's Avatar
It is a B & M. WHy shouldnt you use the Line bias blocker rod or the acumulaor blocker rods?
Old Dec 13, 2002 | 10:05 AM
Nordbert's Avatar
As a last resort..
You might have to fill the tranny, start the engine and put it in
gear (forward or reverse) so the pump will blow the valve into the pan. I've seen this posted on this board or turbobuick.com
deracer
Apr 11, 2016 12:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
Strick1
Aug 27, 2015 08:57 PM
g.l.mos
Aug 22, 2015 12:02 AM
wayshegoes
Aug 17, 2015 12:00 PM
