Difference between Axles??? Help.
Old Dec 15, 2002 | 05:07 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Hey...I managed to come accross all the rear end "guts" (ring, pinion gear, posi unit etc) from brand new 2002 Chevy S10.
The question I have the hopefully someone on here can answer for me is what sort of difference is there in terms of the Axle shafts between the S10's and a 28 spline axle from a 3rd gen?
I imagine they are probably a little shorter, but does anyone have any insight???
Old Dec 15, 2002 | 05:17 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Hey Dave! Actually the axles in the S10 rear should be longer I think. I know that they were longer then my Montes axles anyways. I don't know if that helps?
Keiran
Old Dec 15, 2002 | 06:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The only axles that will fit in a third gen housing are from another third gen (or aftermarket ones). You can use all the "guts" but will need to find a set of 28 spline third gen axles.
www.tomsdifferentials.com has a nice set for $125 each. They're better than factory axles.
I'll sell you mine for $500 Canadian plus shipping from Calgary. Since I went to a 9" I don't need them any more.
Old Dec 16, 2002 | 12:11 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
I think I am going to have to just suck it up and look arround for a set.
I already have a set of 3rd gen axles pulled and sitting in my garage, so once I get the S10 axle shaft I am going to compare the 2 of them......also anyone know if any of the larger GM full sized cars etc may have axle shafts which I could use in a 3rd gen?? (28-spline of course) I was thinking something like a Roadmaster, etc, any older RWD cars.
Old Dec 16, 2002 | 12:14 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Originally posted by Stephen 87 IROC
The only axles that will fit in a third gen housing are from another third gen.
What part of that didn't you understand? No other GM diff has the same length axles as a third gen.
Old Dec 16, 2002 | 09:10 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
no reason to get all testy over it!
Thanks for the clarification.
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
IROCtometal
Sep 9, 2015 10:01 AM
angel2794
Sep 8, 2015 06:22 PM
greenyone
Sep 2, 2015 03:39 PM
