Dumb question prob..but here goes- T-5
Old Dec 18, 2002 | 10:00 PM
91ZLS1's Avatar
I have a 91 Z 305 TPI with t-5. My transmission is shot and was wondering if a world class t-5 out of a 92 mustang GT would work if i changed bellhousings? I am not familliar with mustangs and the dimensions of their trannies and i am not sure about the input shaft and teeth. someone lemme know please, i call numerous trans shops around the area and nobody knows. I can get a good deal that is why i am interested. Also, what about electical connections, VSS and other things that maybe i am forgetting to mention? thanks again
Old Dec 18, 2002 | 10:14 PM
justinhebert's Avatar
Im almost positive it wont fit. I think the casing is is different and in our cars the tranny sits cocked 15 degrees or someting like that.
Old Dec 19, 2002 | 08:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right.... no way. Everything about the exterior of the trans is completely different; bolt patterns, splines, etc. even though everything inside is essentially identical.
Old Dec 20, 2002 | 01:33 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Check out this site. It might help. I'm not sure what your budget is, though.
http://www.fortesparts.com/tremec/tr3550.html
Old Dec 22, 2002 | 01:21 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Just bought a Tremec TKO from Fortes.
Bolts right in.
About $2300 including shipping.
He changes the input shaft to GM Style 26 Spline, supplies an adapter plate so it bolts up to the T5 bellhousing. Gotta space the crossmember down 3/4" of an inch and torque arm bolts right up.
It also comes with a new Driveshaft yoke and adapter u-joint that uses the stock driveshaft.
-Rich-
Old Jan 31, 2003 | 08:42 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Never say never.
Not 100% sure it can be done in an F-body but in has been done in a vette. The guy who had the t-5 in his vette has a bad *** mustang and a 900+horse blowen vette. He is also an engineer who does a lot of fabbing himself.
That silver thing is a adaptor plate he made himself to attach the mustang tranny to the GM bellhousing.
Old Jan 31, 2003 | 12:37 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
advanced adapters makes the bellhousing adapter
Its standard on all fortes tremecs. But, yul pay about 250 for it alone. Once you add all the cost of the other issues (like the input shaft and yoke), you will quickly exceed the cost of rebuilding your WC-T5.
Old Jan 31, 2003 | 01:41 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Re: advanced adapters makes the bellhousing adapter
That's why I sought out a GM w/c t-5 to stick in my vette, it's on the operating table right. Hope to have it done before the spring thaw so I can start playing with my new Formula.
Old Jan 31, 2003 | 02:01 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
ur still going to have the issue of the 15degree rotation
The bellhousing on GM fbodies has the bolt pattern rotated 15degrees counter clockwise to allow the shifter to be angled to the driver. If you use a vette bellhousing, you will loose that,, but then ul have to address the transmission mount being 15degrees from the proper location. Not to mention the hydraulic clutch linkage...
Old Jan 31, 2003 | 03:22 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Re: ur still going to have the issue of the 15degree rotation
Going to try to mount it with the f-body bellhousing first and see if lines up well with the stock shifter hole. I am pretty sure I can piece together a hyd clutch system. I am going to grind off the mounting nubs for the torque arm and see if i can get away with just fabbing a bracket to bolt to the stock cross member which is welded to the frame and also holds my e-brake cable pulley. My goal is to be able to stuff a muncie back into if I need or want to without remodification.
Old Jan 31, 2003 | 03:35 PM
mike48's Avatar
Car: 89 RS (original V6 car)
Engine: 355 TPI
On the Mustang trans- what about swaping out the transmission case, the input shaft, and tailshaft housing from a Chevy T5 to a Mustang T5? Lets say you have a bad Chevy T5 and a good Mustang T5. Has anyone ever combined the 2 to make a good Chevy T5? Which parts will fit and which ones won't?
Old Jan 31, 2003 | 04:14 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
all internal parts interchange
Gear ratios are slightly different.
Fords have a lower first.
midge54
Sep 2, 2015 06:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Cacike
Aug 27, 2015 05:10 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
