gear swap?
Old Jan 31, 2003 | 02:22 PM
ScreaminDeamin85Z's Avatar
gear swap?
i pulled the diff cover on my 89 to find out what gears i have in there now. well they are 3.08s, so this means i have a 2 series carrier right? also i have the 26 spline axles. i have a set of 3.42 gears out of a late model f-bod, now my question is about the carrier. do i have to swap to a 3 series carrier?
Old Jan 31, 2003 | 05:55 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Yes you do have to swap over to a 3 series carrier. A good one would be the zexel take out units from SLP for $99. You will have to change to 28 spline axles, but then you would have a posi that actually works. If you are going to go to the trouble of swapping gears, then why not go all the way and be able to actually put the power to the ground with the zexel.
I really like the way my zexel works in my 87. It's by far the best mod I've ever done to the car. All the other mods to increase power just made the lack of a working posi even worse. Now with the zexel I can actaully use the extra power from the mods I've done to the car.
1984HO
Mar 19, 2021 11:59 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
