Speedo
Old Dec 20, 2002 | 10:30 AM
BurnoutBoogie's Avatar
Speedo
How hard is it to replace your stock speedo in you guage cluster? Just wondering cause im tired of only being able to read 85 MPH on it.
Burnout
Old Dec 20, 2002 | 11:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's very easy.... easiest to change the whole cluster, since then you don't have to take the cluster apart. Takes about 15 minutes to swwap a cluster.
Old Dec 20, 2002 | 12:39 PM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
so if i change it to say a 105 speedo, will it reconize that? Cause i notice when i took mine out for cleaning (85 t/a) that it looks like electrical prongs right? and it should reconize it but i want to make sure before i go looking in scrap yards.
Old Dec 20, 2002 | 12:50 PM
87Formula4bbl's Avatar
Car: '87 Formula
Just make sure you grab a cluster that has the same tach as your old one or it will be way off. Other than that it is a direct bolt-in. I swapped in a 120 from my 85mph gauge. Easy, and works perfectly.
Old Dec 20, 2002 | 12:59 PM
Thanks for the information, but i got one last question: On the does the ECM do anything with the speedo? Does the VSS run through it at all? 'Cause if it does, that could be a problem.
Burnout
Old Dec 22, 2002 | 05:48 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
If you have an electronic speedo the VSS sends pulses to the ECM which converts them and sends them to the speedo gauge. The speedo will work as long as it came out of a third gen f-body.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
