Anyone have probs.. with 4.10s..
I have the stock 10 bolt rear with auburn pro posi....and ive blown out a set of 373's and 4.10s within this year.....i go the correct break in and i never got on for i think 1000 miles..is the rearend just too small and can't handle the torque? What kind of gears is everyone else using...Both my sets were Richmond..well any info would help..thnx!
I have been running GM gears in most the cars I build and I have had very few breakage problems(Thats low 12's in most even my 89 runs a 11.2 with a 7 5/8). You must either have a stick shift and rev and pop it or love to burn tires resulting in substantial wheelhop. Automatics usually don't shock the rear enough to break the gears. You never know how strong something is until you break it! Are you surprised you broke it?
Ya i'm pretty suprised it broke..and i have an l98 auto...when i do burn outs it never has any wheel hop, well at least any wheelhop that i can feel..i dont know..its my 2nd gear set in 5k miles..my car only runs in the mid 13's. could it be improper set up maybe? I had the same shop do both sets. I also have a TA support cover to help it out..well any help would be appreciated.
Yes, I think I would use a different shop. If that L98 is stock to mildly modified you shouldnt be breaking them that quick anyway. If you arent running slicks and are just driving on the street for the most part I doubt you should have been breaking them at all.
Ben
Ben
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
i SHATTERED my axles one night during an attempted 6000rpm launch....needless to say it felt really cool until the thing snapped its legs off.
i pulled out the carrier and cleaned everything, no gear damage
the gears are richmond 3.73's in a 7.5" 10 bolt
moser 12 bolt to come soon
Car: '91 Camaro RS
hehe....well it would have been cool if the rear held out...the pass before that it went 12.7 the motor makes peak power at about 6800-7000
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I've done a 3 gear installs so I'm no expert, but I'd say the setup has alot to do with gear life.
I did re-do a gear set in a Mustang in which the fool that installed it never check the pinion depth and the thing was making a gawd-aweful racket. It almost sounded like an airplane taking off in the trunk. I believe if I hadn't fixed them it wouldn't have been long for them to explode.
BOth time i've done my geat installs...i do the break in and change the gear lube a few times..and after about 2k miles it slowly starts whining then gets hella loud and grenades..4.10's a bad idea with the l-98? Would 3.42 be the better choice?
Car: 88 Camaro
Engine: 355
Transmission: TH-350
Thats what i was thinking...everyone in my area always break 4.10's but then again everyone has em put in at the same shop..everyone arround here says you cant go 4.10s in the stock rear...so thats what i was wondering.
Car: 88 Camaro
Engine: 355
