Degreasing clutch surfaces with laquer thinner?
Old Dec 22, 2002 | 02:17 PM
David Trimble's Avatar
Quick question - I'm getting ready to install my new clutch pressure plate and resurfaced flywheel, and I'd like to make sure the contact surfaces are degreased. Will laquer thinner do the job, or am I better off using something else?
Thanks...
Old Dec 22, 2002 | 02:38 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Laquer thinner,carb cleaner,or brake cleaner spray are all fine to use.Personally I use thinner.
Old Dec 22, 2002 | 02:41 PM
cool- I just happened to spot the lacquer thinner on the shelf, but I've also got some brake cleaner, too....
Thanks!
Old Dec 22, 2002 | 03:42 PM
Thanks!
Old Dec 22, 2002 | 04:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Lacquer thinner is also recommended for cleaning the cylinder walls during an engine rebuild. Even washing with soap and water won't remove all the oil from the metal.
Old Dec 23, 2002 | 10:07 PM
laiky's Avatar
Brake cleaner is good, laquer thinner and carb cleaner are much more hazardous to your health, don't get laquer thinner on your hands, it is absorbed through your skin and is a HD carcinogen. I like brake cleaner and latex gloves, if you go laquer you will need Nitrile gloves or better and some fresh air
sounds trivial but it adds up over the years
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
mfp189
Sep 27, 2015 09:25 AM
