Flywheel/pressure plate torque values
Old Dec 22, 2002 | 11:33 PM
David Trimble's Avatar
Another quick question- does anyone have the torque values for the flywheel to crank bolts and the flywheel to pressure plate bolts for a '84 T/A 305 with 5-speed? I've been going thru my shop manual trying to find these values, and I've noticed that the torque specs table for the 5.0 V8 is apparently missing....
Thanks once again!
Old Dec 23, 2002 | 06:01 AM
ede's Avatar
ede
real damn tight, actually i use a 1/2" impact on the flywheel to crank bolts and a 3/8" impact on the preasure plate bolts, along with some red loctite. i've never used a torque wrench on them.
Old Dec 23, 2002 | 06:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're the same as any other Chevy V8.
Based on the hardware sizes, as torque values always are, they're about 60-65 flywheel to crank, and 30-35 pressure plate to flywheel. The pressure plate bolts are special bolts; don't try to use regular hardware, not even grade 8.
Old Dec 25, 2002 | 11:57 AM
Guys- thanks for the tips!
btw ede- thought red loctite was for 'permanent' attachment- that is, for something you don't plan on EVER removing?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
