VSS without ECM??
Old Dec 23, 2002 | 01:16 PM
BurnoutBoogie's Avatar
VSS without ECM??
I just dropped in a 350 LM1 engine into my Bird, and ripped out any trace of smog and the old sensors. I've read that the VSS sends signals to the ECM witch in turn sends a signal to the speedo. My question is this: Is there a way to get my speedo to work without the ECM, or do I have to go to a cable speedo?
Old Dec 24, 2002 | 12:41 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
you will have to use a cable unless you find an aftermarket solution. If you still have the ecm...put back in and just connect it to the vss and the gauge cluster so it can run the speedo....thats what i did in my car...the only thing the ecm does is make my speedo work
Old Dec 24, 2002 | 06:10 PM
4L60bliss's Avatar
Actually, only '90-'92 F-bods used a VSS buffer internal to the ECM. Your '86 used an external buffer (that little yellow box next the the ECM). It works independantly of the ECM, and will controll your Speedometer, even if the ECM is gone. The ECM is just another "output" to the buffer, so its not needed.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Jlanz55
Sep 29, 2015 08:55 AM
