Help with my 2.73 to 3.42 swap please!
Old Dec 28, 2002 | 07:05 PM
92GTA's Avatar
I'm going to swap the gears and posi on my 92 GTA and I'm bascially rebuilding the entire rear end and I want to make sure I have everything covered before I begin. Here is what I have:
1. New Posi (SLP, 64501T $99)
2. New 3.42 Gears (Motive Performance, $175) w/driven gear (GM, 25513048 $3)
3. Deluxe Gear Install Kit (Ratech, $129.99) Includes: Pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, pinion & carrier bearings, and wheel bearings and seals.
4: Royal Purple w/posi additive
5. Replace rear brake pads and turn drums.
Does that cover EVERYTHING?
Thanks!
Oh, I also read something about needing new "bearing races", what are those? Are they included with the install kit I'm buying and are just called something different?
Old Dec 28, 2002 | 09:46 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The bearing is one part, the race is the other that the bearing rides on. They should be included in the kit.
Old Dec 28, 2002 | 09:47 PM
92GTA's Avatar
Cool, thanks!
Old Dec 29, 2002 | 03:09 AM
MdFormula350's Avatar
yeah sounds like everything..
Old Dec 29, 2002 | 07:40 AM
ede's Avatar
ede
asking the same question more than once doesn't usually result in better answers, especially asking one right after the other.
Old Dec 29, 2002 | 09:14 AM
4L60bliss's Avatar
I didn't see mention of gear marking compound, but I don't see the Ratech kit not coming with some.
It sounds like you have all the parts, now you just need some tools.
Orr89RocZ
Apr 25, 2016 08:28 AM
draco
Oct 4, 2015 09:25 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Regal105
Aug 23, 2015 03:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
