What size ring gear does a 12 bolt have.
Old Dec 30, 2002 | 12:06 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
How much engine power does a 12 bolt take to turn?
I have been wondering forever how much more rotating mass a 12 bolt has over a 7.5 10 bolt. What size ring gear does a 12 bolt have? I am trying to figure out how much more engine power a 12 bolt takes to turn.
Old Dec 30, 2002 | 06:08 AM
ede's Avatar
ede
don't quote me on this but i think 8 7/8"
Old Dec 30, 2002 | 07:07 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Correct.
Old Dec 30, 2002 | 09:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's more to it than rotating mass.... all the bearings are bigger, there's more preload, etc.
"They" say (and as we all know, when "they" say something, it's just got to be true) that a 12-bolt usually shows up as about a 10-12 RWHP hit on a chassis dyno. A F*rd 9" is in the same range. But I've never done a back-to-back comparison myself, so take that for what it's worth.
Old Dec 30, 2002 | 11:06 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
RB, what exactly are you saying about the dyno thing with the 12 bolt "hit"? It shows up as a 10-12 loss? I know I've read something about the 12 bolt causing less frictional drivetrain loss because of it's pinion offset. It's small, something like 1.5 (?) inches compared to something like 2.25" (?) for a Ford 9". So if you could elborate more on what your saying I'm sure we could learn something. Thanks.
Old Dec 30, 2002 | 03:05 PM
Momar's Avatar
I think he is just saying that you loose that much power from turning the larger heavier parts so it never gets to the ground.
Old Dec 30, 2002 | 05:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right.... "they" say that on average, a car with a 12-bolt will measure about 10-12 HP lower than an otherwise identical car with a 10-bolt. The real-world difference between a 12-bolt and a 9" are obscured by indivivual variation from one specimen to another. There's alot more losses going on in there than just the gear mesh, and most of those other losses are alot bigger than that one.
hectre13
Dec 11, 2023 08:14 AM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
