will a 2200 stall mess up my stock rear end or suspension?
Old Jan 4, 2003 | 12:33 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i was questioned on the fact that i plan on getting a 2200 stall for my car.........some people think that it will break my rear end...........should i believe them or not?
i figured i will be fine just as long as i dont put drag slicks on there
right?
Old Jan 4, 2003 | 08:12 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
All I have is the factory rear, I was hoping to implode it when I put in the TH350 w/ 3500 stall, consistent 1.80-1.82 short times but it never happened. I've heard countless horror stories, but I am on the "had good luck so far" list. It will be replaced with a Ford 9", but I'm pretty impressed with the ole girl. Handled the whole season and never gave any sign of letting go.
Old Jan 4, 2003 | 08:26 AM
Z28DJP1987's Avatar
With that Stall Speed (2200) which is only 600 over stock you will not blow your rear axle or supension. Also, I would NOT belive these SO CALLED EXpects, the Torque Convertor has nothing to do with those parts.
Old Jan 4, 2003 | 09:52 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I have a 2800 in my car and haven't had any problems. My best 60ft time was 1.99. My buddy pulled a 1.7x 60ft on this converter behind his LT1 and did have trouble with his rear, but that may have been due to a poor gear install. Defenately get a tranny cooler also.
Old Jan 5, 2003 | 01:54 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
alright.......thanks for the info
im really glad to hear that i SHOULD be ok........ im not gonna get too excited cuz if i do then i will probably end up breaking something .............yah i will most likely get a tranny cooler cuz im getting a built up 700r4 and i DONT :nono: want it to break.........lol
Old Jan 5, 2003 | 05:07 PM
iroc_cragg's Avatar
I dont think it would be a problem. I am thinking about adding a 2000 Stall to the 305 TPI. Do u think thats a good Stall for a mild 305 TPI or should I go bigger. I have 3.42 gears also.
Thanks alot
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
