Interesting flywheel info.
Old Jan 6, 2003 | 11:26 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I just got off the phone with a long convertation with the local GM dealer about flywheels. this is what i found out, it may or may not be of interest to people, but might help some who are confused.
GM lists 2 part numbers for flywheels for 87+ F-bodies.
14088650 - is listed for VIN E - 305 TBI. this is listed as a Std Weight 153tooth flywheel for the 10.4" clutch
14088446 - is listed for VIN F - 305 TPI, this clutch is listed as a light weight flywheel 153 tooth for 10" clutch.
both myself and the sales person thought this was a little odd, so we looked up the clutch disk,and presure plate part #'s for both the TBI and TPI engines. the both list the clutch disk as 10.5" same part #, same pressure plate part #.
so we figure it is just a whole series of typos (GO GM!) and that either of those part #'s for the flywheel are usable.
anyway this has probably been said before, but when i did a search for flywheel, i couldnt' find much info, and because of that i called the dealer
Pac J
May 17, 2020 10:44 AM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
okfoz
Oct 13, 2015 02:19 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
6998poncho
Sep 25, 2015 02:56 PM
