Where on T-56 slave cylinder is this
Car: Tahoe
I'm looking for the bleeder screw on this slave cylinder for my t-56 and don't see it. If it is blatantly obvious slug me then treat me like a child and tell me where it is. Please.
Car: 1989 IROC-Z
Originally posted by breathment
sorry. it doesn't exsist..
we have a winner.
i just bled mine through the tube up to the master cylinder.
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
If you end up with air in the line you can get it bled out even without a bleeder. Just fill the reservoir and loosen the tube at the base to get the fluid down as far as possible and then just pump the clutch pedal a bunch. Try some slow applications and some fast ones and it will work its way out eventually.
