TV vs. Vacuum Modulator.. Pros/Cons?
Old Jan 10, 2003 | 08:37 PM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
Just in the interest of how things work..
What are the pros and cons to using a TV vs. a vacuum modulator? (The 350 and 400 use a vacuum modulator, and the 200-4R and 700-R4 use a TV cable.)
From what I can see the vacuum modulator sounds like a better deal (working off load instead of throttle position) but seems less reliable (vacuum leaks can cause problems, etc.)
Thoughts?
Old Jan 10, 2003 | 11:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Actually the TH350 has a throttle-valve cable AND a vacuum modulator.
Old Jan 11, 2003 | 06:54 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The primary reason for changing to a TV valve was to eliminate the possibility of engine age and vacuum leaks causing alteration of the shift points. It is also a little more precise in controlling line pressure than a vacuum modulator.
Old Jan 11, 2003 | 09:38 AM
Ken73's Avatar
Car: 82 Corvette
Really? My old truck that had a TH350 in it didn't have a TV cable - just a vacuum modulator. How does it have both?
Old Jan 11, 2003 | 11:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 350 does not have a TV cable, it's only a kickdown cable.
A vacuum modulator is far superior to a TV cable, because it measures the actual thing that the transmission needs to react to, namely engine load. With a TV cable, the transmission has to "guess" what the relationship of throttle position to engine load is.
It always makes sense to measure the thing that actually indicates the condition you want a servo system to respond to, rather than measuring some other quantity that might or might not relate to it. Rather like the technical superiority of using a MAF for measuring air intake volume (literally counts air molecules) rather than speed/density (tries to infer number of air molecules by guessing based on engine vacuum and RPM and throttle position and so forth).
Old Jan 11, 2003 | 11:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The vacuum modulator line goes to a manifold vacuum port, and there's a kickdown cable that goes to the throttle arm.
Old Jan 12, 2003 | 12:23 AM
Ken73's Avatar
Car: 82 Corvette
That's what I was getting at. I've been digging into transmissions a bunch now and I wondered why they went to a TV cable instead of a vacuum modulator. Now that I understand what they each do (same thing) I couldn't figure out why they basically went *backwards* on it. (Other than lack of reliability on the modulator, but that kinda failure is rare these days from what I've seen.)
That being said - I wonder if converting (blasphemy, I know) a TV cabled transmission to a vacuum modulator would improve it any? I also have to wonder if that would give it a little more longevity; seeing as how it would apply a more correct amount of pressure versus load...
Old Jan 12, 2003 | 03:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It doesn't behave the way the TV cable on the 700R4 does, but doesn't GM call it a TV cable?
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
