A second opinion on my T5 input shaft...
Old Jan 13, 2003 | 08:18 PM
David Trimble's Avatar
Took the input shaft in to the local tranny shop to have the old bearing pressed off and the new one pressed on. The machinist took a look at the gear and commented that it was worn. Reason: he found a spot on the side of one of the teeth about 1/16" diameter that looked a bit rough. The rest of the teeth looked fine.
I had known about that spot, having inspected the teeth the previous day but I had thought that was probably a manufacturing defect. If there was a wear pattern like that I would be conncerned but since it was on just one face of one tooth I'm not sure if it's worth replacing the part.
I'd say I should run with the part. Any opinions either way?
Thanks once again!
Old Jan 14, 2003 | 10:07 AM
Fastcamaro87's Avatar
In the t-5 repair manual i have it says that u can blend small chips with a grinder and basically just deburr any rough edges. I dont have to much experience with this subject so im not positive. If i were you i would contact HanlonMotorsports.com they are very nice people and great to do business with, they will most likely be able to tell u what u need to know.
Matt
Old Jan 14, 2003 | 09:56 PM
Matt-good idea. On a recommendation, I bought their 'how to' video on rebuilding T5s. I'll give them a ring and see what they think. Due to funds I can't really afford to replace it unless it's chewed up. This thing wasn't chewed up by a long shot, and I'm not replacing it over what I could consider to be a cosmetic defect.
cheesehomer
Dec 31, 2015 08:48 AM
camaro71633
Sep 1, 2015 10:24 AM
Chipguy
Dec 15, 2002 09:38 AM
Twilightoptics
Oct 20, 2000 01:11 AM
