wanna change my 700r4 trans mission over to a manual what do i have to have
Old Jan 14, 2003 | 12:33 PM
z28man4life's Avatar
i have a 1991 z28 camaro witha 5.7 liter engine. my trany is slipping and has been for a while. i have a manual out of an older firebird that had a 2.8 liter,will it work the firebird was fuel injected. i think a manual will set this car on fire but i have to know what to have, any advice is welcome.
Old Jan 14, 2003 | 12:46 PM
MILT's Avatar
the V6 t5 has different parts than the V8 one. Also, check the tech articles for auto->manual swap. If that's not enough info, do a search on this board. You'll find more than enough info...
Old Jan 14, 2003 | 12:53 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
I do not know much about transmissions but I do know that you will not be able to bolt up ANY T-5 with an L98. There is a reason why that specific engine only came mated to a TH700-R4, and that is: THe TH700-R4 was the only available transmission to handle the amount of torque put forward by torquey L98. V6 and V8 trans have different bellhousings from what I hear, you might want to look into a T-56 out of a fourthgen, you'll get 6 gears, all of which are of good ratio, and they can handle the torque of an LS1, so you know that you should be good to go. Just a heads up, good luck with your project.
Old Jan 14, 2003 | 01:08 PM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
You can also opt to rebuild the transmission yourself, and use a TransGo Reprogramming kit that will make the 700R4 fully manual.
Old Jan 14, 2003 | 04:13 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Actually a few L98s did come with T-5s.. at very very special request.. we're talkin 3-5 units.
The V6 T-5 is not suitable.. your chances of finding the right clutch for the V6 T-5's 14 spline input shaft to mate up with the L98 flywheel are slim... Had a friend who put one behind a 406 poncho, but I can still barely believe he didn't grenade it in a week.
I would have to agree with PimpRod... look into the T-56. They're bulletproof (rated 450 ft-lbs tq stock if I remember correctly) compared to the T-5, and that .5:1 6th gear is a godsent for highway mileage.
If you don't know well enough to not try to stick a v6 transmission behind a v8, I wouldn't suggest trying to rebuild your slushbox yourself.. just an opinion on that note.
Old Jan 16, 2003 | 07:53 PM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/t...nualswap.shtml
Old Jan 16, 2003 | 07:56 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I wouldn't waste my time with the T5 as chances are you won't be the lucky one to have one hold up behind a 5.7. I would go with a T56 and depending how mechanical incline you are will determine if you can install it yourself or not. The T56 is definetely the way to go with the best of both worlds. It has a nice .50 overdrive for fuel economy and is near bullet proof for what street motors dish at it.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
maroe624
Apr 16, 2017 08:29 AM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Aug 6, 2015 04:15 AM
