Installing diff gasket. Quick question.
Old Jan 14, 2003 | 05:50 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
After changing my bent axle I'm now left with fitting the diff gasket. It's a paper gasket so I presume I just use some RTV silicone on each side to seal it? How much?
How long should I leave it before adding the diff fluid?
Any other suggestions are welcome.
Robert
Old Jan 14, 2003 | 06:09 PM
82camaro's Avatar
Car: 82 camaro SC
I never use the gasket, just some rtv sealant. Waiting until the silicone on the outside firms up is probably a good idea.
Old Jan 15, 2003 | 12:48 AM
jeffs82z28's Avatar
I would use some High tack gasket sealant and the
paper gasket. But that's just me.
If you must use rtv, use the Ultra Grey, we use it at
Kenworth to seal up rear ends instead of gaskets.
Old Jan 15, 2003 | 05:56 AM
ede's Avatar
ede
i second the high tack, great for holding it in place, on the machined suace you shouldn't need any sealer, i use ultracopper on the pan side.
Old Jan 15, 2003 | 03:16 PM
82camaro's Avatar
Car: 82 camaro SC
What I prefer to use is called 'the right stuff' Very cool stuff.
http://www.permatex.com/right_stuff/right_stuff1.asp
Old Jan 16, 2003 | 11:34 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks for the replies. Finally got a dry day so was out today and finished the job. I used a paper gasked and a thin layer of gasket sealent. Hopefully this will do the job. I'm leaving it overnight and filling the diff with fluid tomorrow.
draco
Oct 4, 2015 09:25 PM
NinjaNife
Aug 23, 2015 11:49 AM
crazynights
Aug 21, 2015 06:53 AM
TheJoeY88
Aug 13, 2015 06:51 PM
jahblah
Aug 12, 2015 05:54 PM
