carrier ?
Old Jan 18, 2003 | 04:28 PM
black83z's Avatar
carrier ?
I am installing a new motor in my car with a cam, and gears would certainly help get it into it's power band much better. I currently have a 83Z with 2.73s and an open differential. Can i put gears and posi into this carrier? Is it different from carriers that originally came with posi? What series carrier is it? I was also curious as to whether or not it was possible to put 28 spline axles into my carrier that has 26 splines. I did a search and heard that it was a straightforward swap, and i also read that 28 splines were too big to fit. Whats the correct answer? Thank you very much.
Matt
Old Jan 18, 2003 | 04:32 PM
4L60bliss's Avatar
A posi is the carrier. So when you buy your posi, make sure its a 3 series 28 spline, and then you can use 3.23 and up gear ratios and 28 spline axles. Yes, as long as you buy a 7.5-7.65" carrier and axles to match, it will be a direct swap.
Old Jan 18, 2003 | 11:07 PM
black83z's Avatar
NICE. Wow, that cleared up a lot. Its good to look like an *** by askin a question than just guessin. Thanks.
Matt
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gord327
Oct 3, 2015 01:25 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
