what spline is my 1982's rear?
Was wondering if anyone can tell me what spline is in my 1982 trans am. I think its a 3.73 posi. I want to put a newer rear in with a better gear ratio for highway cruising and I think they changed the spline after a certain year. Anyway if you know please post. Also what exactly is the spline? would I need a new driveshaft if I got a new rear?
Sorry, meant to answer the whole question in one post. The spline is the number of splines on the axles and in the carrier. Changeing gears has no effect on the spline. You would only have to worry about that if you were changing axles or carrier. Hope this helps.
Originally posted by smoove2022
thanks for the input! what is the carrier?
So are drive shafts interchangable from transmission to transmission and from rear to rear from 82-92?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
driveshaft splines same from 200c to 700r4 to th350 to t-5 to saginaw 4 speed, lengths changed from 700r4/t5/longtailth350 length to 200c/shorty th350 length
two different lengths 82-92
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
if its stock..it aint 3.73s... 3.23 was the lowest gearset you could get in 82.
and 26 spline is right.
i have a th350 with 3.23s and i cruise 65 at 3k rpms
hmmm, you may be right. I was going off of something I remember reading in a dealer booklet from 1982 a while ago. I thought it said that one of the features of the ws6 was a 3.73 rear ratio. I'll try to find that booklet again and double check. If your engine is doing 3k at 65-70mph with 3.23's then your probably right. Guess that means I might put a 700-r4 in instead. By the way nice '82
Engine: 383 -305
Hopefully theres a pic (or a link to a pic) of my baby below
yeah i'll be swapping over to a t56 this fall... i converted my red 82 over to 700r4...not that difficult but you'll need to mod the frame rails.
btw thank you for the compliment...
*** you have one of the nicest 82's i have ever seen..that thing is pure badassssssssssssss!!!!! you have any other pics of it ? id love to see some..
Engine: 383 -305
Hey Markb what type of modifications did you have to make to your frame rails in order to accept a 700r-4? Oh yeah and here is another pic.
btw that car is so beautiful man!!!
Thanks for the compliment!
Actually I was wondering if you had to make any changes to the center console/shifter. Being that the 700r4 is a 4-speed and the old 200-c is a 3? I guess I'm wondering if the "D" position will still be drive or will it be overdrive, or if the "2" position is now drive and the "D" is overdrive... that kinda thing. I hope that made sense... I have a 700r4 in my basement and I have been meaning to put it in but the swap is a little daunting to me. Ive never swaped a tranny or an engine for that matter.
Engine: 383 -305
oh man...its so incredibly easy!!! yes you'll need to swap the shifter for a 700r4 shifter. do the swap!! its so worth it! if you run into problems let me know..ill be glad to help you out.
Car: 82 camaro SC
Yep, the 700r4 swap is worth it!! I installed aftermarket 3.73's and without overdrive it was revving pretty high down the highway. Your computer 'may' still handle the lock-up. It doesn't know if you have a 3 or 4 speed tranny, it just locks the converter when the conditions are right. Or you could install an aftermarket non-computer 700r4 lock-up kit. TCI, B&M, Painless, etc... Or you just put in a manual switch. For the crossmember mods, I took a different route. I cut up the original crossmember, moving the center of it back a couple of inches, and welded and reinforced it. Installed a Megashifter to handle the extra gear.
Engine: 383 -305
as far as the tcc lockup...i had mine rigged to a switch,cant exactly remmeber how i wired it...{i got the info off this board though} its been awhile since i did that hehe.
Engine: 4.3L Z TBI
only two wires for lockup, easy, and summit seolls lockup wire kit for not bad price,
ive got an 82 trans am also,
its LG4, 200c, and 3.23 or 3.08- i have no idea what ratio it is yet, and the original power bulge hood even- still in perfect shape,
car is painted '70 or so chrysler purple haze,i plan on ditching the fresh rebuilt 200 for a th350 longtail and buildign an 86 LG4 from a station wagon into an L69 with summit 9.16CR pistons(58cc 22601 heads)
ill worry about rear axle ratio and pass side fender at a later point,the car has issues with the rear wheel arches so its just gonna be beat on and railed hard... but the doors are mint and shut tight like brand new, so hmm..
good luck
good luck
Engine: 383 -305
good luck
good luck
hectre13
Dec 11, 2023 08:14 AM
Genopsyde
Oct 7, 2015 08:35 PM
hectre13
Aug 26, 2015 08:17 AM
