My question is about the sep. plate. They want you to fill a couple of holes in the plate with some small aluminum slugs they supply. I don't like that idea. I was thinking about JB weld or soldering. Has anyone had expierence trying this or something else? Not sure if the trans fluid would affect the JB weld or not. Any ideas?
Thanks.
Gary
Thanks.
Gary
As long as you follow the directions, you won't have any problems w/ the plugs. Myself and others have installed several of these with no problems. If you chamfer both sides of the hole and flatten the plug on both sides, it won't go anywhere.
GM Tech, I programed mine with the automatic version. What kind of a difference should I expect?
Gary
Gary
