Clunking when put into gear...
Old Jan 23, 2003 | 01:06 AM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Ok, I read all through the archives and still cannot come up with an answer. I just put a T5 in my car (was auto) and now every time I shift there is a harsh clunk coming from the rear of the car. It also repeadely clunks when u let off the throttle in 4'th or 5'th gear and the rpm's are low. I KNOW it is not the trans mount, because I have a spohn torque arm and a brand new poly mount. So i'm thinking (hoping) it's either the u-joints at the rear or the rear itself. I have a 3.23 locking posi, just put synthetic fluid in it not too long ago. Anyone have any ideas?? What do u have to do to check the u-joints?? All help is appreciated. Thanks
Old Jan 23, 2003 | 01:15 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ujoints if worn out will be physically loose when you grab hold of driveshaft and try to move it around, also check your torque arm and rmount out, its gotta be one or the other problem
Old Jan 23, 2003 | 07:48 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I second the ujoints and check the trans mount as well.
Jake_92RS
Jan 28, 2020 10:37 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
BlackBoulder
Aug 11, 2015 11:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
