rear end help
Old Jan 26, 2003 | 01:45 PM
i_alex's Avatar
Car: vistacruisa
Engine: 532
Transmission: mousburgg
Axle/Gears: 4x4
rear end questions
ok i'm about to put a new set of gears in my 1991 rs it's a 10bolt 273 obvsouly and i was wondering what information i need to know when i go to replace it with 373 psoi rear end. for exapmle what size the rear end is and what spline it is. please help. thanks if i was to go to a junk yard what should i ask for.... as in what other year cars would have the set of gears and things like that.
Old Jan 26, 2003 | 02:27 PM
MdFormula350's Avatar
i think you should have 28 spline axles...
http://www.slponline.com/view_produc...RTNUMBER=64046
http://www.slponline.com/view_produc...TNUMBER=64501T
i think thats all you need other than an install kit.
https://www.thirdgen.org/techbb2/sho...hreadid=156996
Old Jan 26, 2003 | 02:52 PM
ede's Avatar
ede
you need a 28 spline carrier, should be 3 series and a gear set to match the carreir and an install kit. might want to consider a solid sleeve and a rear cover girddle
Old Jan 26, 2003 | 04:31 PM
i_alex's Avatar
Car: vistacruisa
Engine: 532
Axle/Gears: 4x4
what size is the rear end on the 91 rs's 273?? is it 7.5" or 8"??? or whatever it is??
Old Jan 26, 2003 | 07:28 PM
Fastcamaro87's Avatar
its a 7.5 10 bolt a.k.a. 7.625 10 bolt , do yourself a favor and get new gears, a complete install kit with all new bearings, and pick up a Zexel Torsen Posi. its a much better idea to d oeverything once because if you have to pay twice to have the same job done, well you get the idea. MDformula350 posted the link to the zexel its like $100 and well worth it, as for gears i just bought a set of 3.73`s and an install kit from www.randysringandpinion.com for $315 including shipping and everything. so for gears/install kit/Posi your lookin at $430 and then whatever installation costs you.
Old Jan 26, 2003 | 09:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.drivetrainspecialists.com...=28&cat=GM+7.5
Every rear end part known to exist
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
