T-56 Fitting My CAR!?
Old Jan 29, 2003 | 11:04 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i want to get a t56 in advance for my 383 stroker but would like it on my car now. will it directly botlt up to my 1991 z with the t5 already in it or will i need to change some stuff. also will i need a different driveshaft maybe. like a shorter one?
Old Jan 29, 2003 | 11:37 PM
BORLAZ06's Avatar
check these links out...lots of info.
http://www.skulte.com/T56.html
http://www.sethirdgen.org/t56.htm
thy also sell the Aftermarket T56 that is a direct replacement for the T5. either way you go ur driveshaft will need to be shortened 2 inches.
Old Jan 30, 2003 | 05:07 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Wha? you have to shorten the driveshaft? I've never heard of anyone ever needing to do such a thing. O_o
Old Jan 30, 2003 | 10:55 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
if you get a t56 out of an early 4th gen f body, you dont need to shorten the drive shaft. you could also do what i did and use the 4th gen's drive shaft with the 4th gen T56 .
customblackbird
Aug 15, 2021 10:16 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
armybyrd
Aug 10, 2015 09:23 PM
cRoe4
Aug 7, 2015 08:46 PM
