Bellhousing
Bellhousing
I have built an engine for my TBI t5 bird. I'm using a 350 4bolt out of a 79 truck. I put a cam in it and all. I was told by an expert that the bellhousing from a 93 firebird with an LT1 had a T5. It used the same size flywheel as the old engine. (11 " disk compared to my 10 ". I would like the Part # for it I went to GM but their computer is wrong, giving the part number for a six bellhousing. Thank you.
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I hate to say it, but it sounds like the expert was wrong. In '93 GM started the fourth gen birds and camaros and teamed the LT-1 up with the T-56 6 speed. I currently have a 6 speed from a '93 in my '84 TA. No fourth gen's with v-8's used a t-5
sorry to inform ya. In any case, finding a bellhousing that will fit around the 11" flywheel and allow you to bolt up a t-5 may be tough, check into the Lakewood unit though, I'm not sure if an 11" will fit inside that or not, but it's possible! The T-56 uses a flywheel that's the same diameter as the T-5 unit, but has a friction surface to accept an 11 inch clutch, maybe you could check into something like that. With a 2 piece rear main you'd have to either re-drill the LT-1 flywheel for the 2 piece bolt pattern or get an aftermarket unit that's already drilled for a 2 piece rear main crank. My flywheel is a re-drilled LT-1 unit and it's working out great! I hope I answered some of your questions, if ya have any more don't hesitate to ask!
-Paul
sorry to inform ya. In any case, finding a bellhousing that will fit around the 11" flywheel and allow you to bolt up a t-5 may be tough, check into the Lakewood unit though, I'm not sure if an 11" will fit inside that or not, but it's possible! The T-56 uses a flywheel that's the same diameter as the T-5 unit, but has a friction surface to accept an 11 inch clutch, maybe you could check into something like that. With a 2 piece rear main you'd have to either re-drill the LT-1 flywheel for the 2 piece bolt pattern or get an aftermarket unit that's already drilled for a 2 piece rear main crank. My flywheel is a re-drilled LT-1 unit and it's working out great! I hope I answered some of your questions, if ya have any more don't hesitate to ask!-Paul
It is available. It's listed in several books and on GM computers. 93 firebird LT1 5 speed. But it lists the number for the 6 cylinder. And it my transmissions experts books it's there. there weren't many made, that's the thing.
Car: 1992 Firebird
sorry to inform ya.
sorry to inform ya.
Let me know what's up, ok!
-Paul
