Transmission Grinding Into Reverse
Old Feb 11, 2003 | 10:22 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
My transmission is making a grinding noise when I shift into reverse. Is my tranny about to die? The only thing that has been done to it was a corvette servo install about 3 weeks ago. The transmission fluid appears to be at the right level. Any ideas??
Old Feb 17, 2003 | 11:01 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
ttt
Old Feb 18, 2003 | 05:49 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
yeah mine does that too! what is that!?
Old Feb 18, 2003 | 05:51 PM
Car: 1984 Z28
grrrrr
also, how do you check the tranny fluid without taking anything off? other then mabey the fill spot on it.
Old Feb 18, 2003 | 09:33 PM
Redliner's Avatar
Car: Tahoe
Clutch is going out?
With the hydraulic systems the clutches are good to the last drop.
Old Feb 18, 2003 | 09:57 PM
Car: 1984 Z28
meaning.....
they dont wear out as quick?? cause i have a hydralic one...
Old Feb 19, 2003 | 01:21 AM
Redliner's Avatar
Car: Tahoe
No... wear patterns are linear. It's good to the last drop, meaning that the clutch is good until it is really ready to crap out on you
Old Feb 19, 2003 | 05:36 PM
Car: 1984 Z28
how do you check tranny fluid with out physically taking the tranny out.. obviously there is a way.. im just an idiot
Old Feb 19, 2003 | 06:44 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I'm not sure about your car but mine, and all other cars that I have seen have a dipstick, just like the oil. It is close to the firewall.
Old Feb 19, 2003 | 06:45 PM
Car: 1984 Z28
i definatly dont have one of those
Old Feb 19, 2003 | 07:02 PM
Redliner's Avatar
Car: Tahoe
T-5: two holes
one drain one fill
Put car on stands
Use standard socket wrench
Insert into the top bolt and romove
insert pinkey
Feel for fluid
fill till it runs out.
Best way to fill. You will under stand if doing it alone.
1 squeeze bottle
4" of rubber hose. collant over flow hose 1/4" id
Fill with ATF
Don't post to verify ATF, USE ATF
Old Feb 19, 2003 | 07:04 PM
Redliner's Avatar
Car: Tahoe
Some body doesn't know their cars here?
One of you has a t-5 and the other has a 700r4
someone needs to clarify themselves
Old Feb 19, 2003 | 09:21 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Apparently 84z28 has a T-5. I have a 700R4.
Old Feb 20, 2003 | 12:03 AM
Car: 1984 Z28
lol.. which is better?? T-5 or 700r4, whats the difference? im still kinda new to the whole car scene, i know lots of ****, just not everything.
Old Feb 20, 2003 | 12:19 AM
Redliner's Avatar
Car: Tahoe
t-5 Manual (T: top loader, gears go in from the top of the case , 5: 5 speeds)
700R4 4 speed auto with last gear being over drive
Old Feb 22, 2003 | 02:25 PM
Car: 1984 Z28
ohhhhhhh!! thats what i figured but i didnt know that toploader ****.
Old Feb 25, 2003 | 12:29 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
just a little advise, if you are grinding into reverse. first put the trans into 5th, that will synch the gears and then put it into reverse. this will keep you from grinding and extend the life of your trans. not a fix but a little help.
Old Feb 25, 2003 | 05:18 PM
Car: 1984 Z28
so grinding is somewhat normal??
Old Feb 25, 2003 | 05:23 PM
Car: 1984 Z28
by the way, mine doesnt really grind, it sort of goes.. grrrr THUNK!
lol
Old Feb 25, 2003 | 09:55 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
That is what mine is doing. But only when going into reverse.
Old Feb 26, 2003 | 10:05 AM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Yep, it did that on mine when i first got it. Reverse is not a synchronized gear so with wear it will grind. i always put it in 5th and then right into reverse and no grinding.
Old Feb 26, 2003 | 05:31 PM
Car: 1984 Z28
im giong to start doing that, thanks for the tip!
Old Feb 26, 2003 | 05:33 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
You bet, thats what were here for.
Old Apr 28, 2012 | 08:11 PM
dtedrow's Avatar
Car: 1989 pontiac firebird trans am GTA
Engine: TPI 350
Transmission: auto 700r4
Axle/Gears: borg warner 9 bolt and 3.27
Re: Transmission Grinding Into Reverse
i have a 700r4 trans and it grinds in reverse and when its in drive anybody have any thoughts on it?
Old Apr 29, 2012 | 12:12 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Do the above. If it is still tough from time to time, pump the clutch once while in neutral, THEN put it in 5th and reverse.
Grinding in reverse is usually a clutch adjustment problem however. Make sure you have the proper free play adjusted on it, that it is fully bled, and the slave cylinder is completely full
If adjusted properly, it should stop the grind going into reverse
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
