Clutch
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Clutch
I am a po' boy and am gettin ready to replace the busted t5 in my bird (comon tax returns - comon tax returns) and I of courst have to replace the clutch (it is dead too). I was going to get a cheapo at autozone ($100) bt I saw this one on summit -
Vendor: RAM Automotive Company
Product Line: RAM Premium Replacement Clutch Sets
Diameter: 10 1/2 in.
A clutch for your daily driver
Chevrolet/Pontiac: 1982-92 5.0L Camaro/Firebird, 10 1/2 in. diameter, 1 1/8 in. x 26 spline input shaft, replacement clutch set
This RAM premium replacement clutch set is the first choice of professional installers because it contains the correct replacement parts to ensure a proper fit and operation in your vehicle. This clutch set is great for vehicles with no modifications such as taller gears, tires, nitrous oxide, or blowers.
Sold as a kit.
I was wondering if anyone had this clutch and if so any complaints? Also do you think it would give me any better preformance than an auto zone cheapo?
Sold as a kit.
Car: 4
Engine: 6
Transmission: 5
I've had several Ram clutches over the years, in some Chevelle SS396s and in some older Z28s; they were excellent products. Worked fine for years. I wouldn't hesitate to use one again.
I would not try to cheap out to the max on a clutch; it's too much work to have to keep going back and doing it. Stick with a brand-name one, such as Ram, CF, B-W, Hays, McLeod, Dana, etc.; or one from a reputable parts store such as NAPA. A cheap clutch will cause you more grief and expense than it's worth.
Car: 98 Z28 vert
Thanks. As for going cheap.. My car is almost bone stock I don't need anything special yet and can't justify $300 for a clutch so stocker(ish) it is.
Car: 4
Engine: 6
Transmission: 5
True dat.... but don't go with the low bid, you'll be unhappy.
The Ram will give you far better service, longer, with less trouble, and will just all-around work better than a cheeeeepie, as would any quality one. The B-W "Brute Force" series is another good one for a stock or near-stock car, for very little more than a low-bid one.
Car: 98 Z28 vert
Actually tou are really near where I am. What stores do you know of that carry dicent clutches for the 100 - 150 range?
Car: 4
Engine: 6
Transmission: 5
Cool!
No actually I don't, I've only lived here a few months, I just moved here from So. Cal., and haven't had to buy one yet....
The Ram set that you can get from Summit is probably as good a choice as any, and should fit that price range.... seems like the last one of those I bought was about $130 or $140 but it's been a while....
Car: 98 Z28 vert
Summit has the ram for $150. They also have this roller piolt bearing thingy that is like 12 bucks so i will prolly get that too.
Do you know how good the various parts of the kit? Like if I were to get the ram and later on get a partial new clutch, like say a pressure plate will that work or is all matched clutch components recommended?
