700R4 doesn't shift out of 1st
Car: '85 Berlinetta Hardtop
Engine: 388
I recently bought a 700R4 from a salvage yard - It had just been removed from an 86 TA and was still connected to the TPI motor when I first saw it. I installed it in my 86 IROC and it won't shift out of first. Reverse works fine, and drives in 1st fine, but it won't shift! I adjusted the TV cable according to the Tech Article (basically reset it, and then applied full throttle and listened/watched for the ratchet action).
Anyway, has this happened to anyone, and do you guys have any ideas what I should be looking at? Any help is greatly appreciated!
Hi Andy , yes the same thing happened to me. All I did was install a different shifter. I didn't touch anything inside of the trans. just moved the lever on the side to adjust the shifter. It never shifted again. I had park, neut. rev. and first. It's still sitting on the floor in my garage . If anyone knows the anser I would be interested also.
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
you need to adjust the shifter cable if memory serves me right, about the same thing was happening after i installed my B&M megashifter, i had reverse, nuetral, and first, no park and no 2,3,4. Adjusted the shifter cable underneath the car on the driver's side of the tranny (hooks up to a lever that kind of resembles an upside down hammer) and it works perfectly.
pop off the gov cover
check out the govenor gear, you can pop the cover off and pull the govenor gear out and check the gear on it, and check the valve also. This is a sign since 1st and reverse is working. Good Luck
Engine: 388
Thanks for the advice. I'm pretty sure that my cables are adjusted properly, so I'll investigate this govenor gear theory next. At this point, I don't even know what a govenor gear is, or where it is, so if you could spell it out for me that would be really cool...
I've got the same problem with the 700R4 in my conversion van. It used to just skip second and go into 3rd and not even go into overdrive, but taking it down the road last week, it just stayed in 1st
So, I took a governor out of another transmission to put in the van. The one in the van is bad, So we put in the good governor and it still won't shift out of first.
BTW, the transmission was just rebuilt and I just got done putting it in a few months ago.
Engine: 388
Governor Theory...
Well I removed the cover and pulled out the governor and there it was - A totally messed up plastic gear. So big thanks BrandenCali - I can't recall the last time I was so happy to see a screwed up part! I have high hopes for this transmission once I get that replaced. Again - thanks a lot!
Re: Governor Theory...
and you did it yourself. Thanks for the Big Thanks
Now if you don't have a Vette Govenor you can always get one and mess around with it. See if you get better shift points. If you have say 2:73 gears a Vette Govenor will help out alot. You can always learn to put in a Boost Valve in also. Then before you know it you can learn to remove the Valve body and instal a shift kit. Good to see another 3rdgen back on the road. I have the same problem guys, friend drove the car over a parking curb and bottomed out the car bad, that night the trans stoped shifting out of 1st and slipped to red line. Could it be the govenor or something small? I am planing on a trans swap next weekend cause some guys think the trans went. Fluid looked fine.
someone972
Aug 30, 2015 12:52 AM
1st, 700r4, 700r4governorreset, 82, cable, camaro, doesnt, govener, governor, housing, indianapolis, indianapolisq82, iroc, locate, rebuilt, shift, trans, transmission, wont
I will check in the morning
