help>think its a gonner!!??
man, I finally got my Z back on the road and took it down to the track. Mods are in sig but since then I have added Nicely ported Vortec heads/SDPC manifold and an Extreme energy cam.
Driving around town before the race, all was normal, tranny shifting beautifully, etc.
At the track it ran OK all night.
Got home, pulled car off trailer and parked it for a day. Went to drive it today and no 2 gear until like 6000+ rpm. Came back, checked the fluid....VERY LOW...Like off the dipstick completely! Added about 2 quarts to get it back were it needed to be.
Went for a ride...same thing. Nothing until 6K+ rpm. All the gears are there...but I have to be running like WOT.
This trans/converter is stock except for shift kit. 90,000 miles on it. Launching on slicks w/ nitrous...the works. So, can it just be a converter or the trans or BOTH???
I have a feeling its time for a Pro-built.
Car: Take
Engine: Your
Transmission: Pick
GM Tech & Pro Built...thanks for the replies. However, another thing came to mind. Recently and VERY Rarely, the shift points seemed to be a little higher at times than others. And I'd say to myself WTF?? but after tapping the throttle a couple times or just going WOT for a second it would be fine. Again, this happened maybee 2 or 3 times in the past couple months of driving.....weird huh???
Car: Take
Engine: Your
Transmission: Pick
Once again, sounds like a Throttle Valve issue. In stock form, there is nothing but fluid pressure behind the throttle valve to move it back to the "MIN" position. They usually get stuck in the "MAX" position, but could easily get stuck somewhere in between. Remember, the tranny shifts based on Throttle Position -vs- vehicle speed. The more throttle you give it, the later and firmer the shifts are.
