Do converters slip above stall speed??
Old Feb 18, 2003 | 10:03 PM
CamaroX84's Avatar
I know converters slip below the stall speed on auto transmissions (they have to otherwise cars couldn't idle in gear, and major bog would persist). At stall speed, there is supposed to be no slipping between the engine and trans. But what about above the stall speed, does the converter slip then??? Thanks.
Old Feb 19, 2003 | 06:12 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
on drag racing rpm formulas i've seen , you can figure in 300- 400 rpm on the big end of the track. the only way you don't get any slipping is with a lockup torque converter
Old Feb 20, 2003 | 12:29 AM
JPrevost's Avatar
Car: 91 Red Sled
and even the tcc slips by at least 2%
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
Jake_92RS
Aug 17, 2015 09:42 AM
