Sgi-5 mounting location
Old Feb 20, 2003 | 12:03 AM
Redliner's Avatar
Car: Tahoe
Where did you mount your dakkota Digital SGI-5 and where did you tap into the wires?
Old Feb 20, 2003 | 12:34 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Mine is under the upper part of the center console (from a 97 TA). If I remove the two screws that hold the upper console and pull it up I can access the box for calibration changes (not that it happens often - if at all, but still..... think ahead when you mount it).
The wiring is not really tapped into anywhere.... more like all new stuff has been ran to and from the VSS and the SGI-5 and then the output of the SGI-5 is spliced into the existing VSS signal-in wire in the trans tunnel above the trans near the firewall. Power is off the accessory circuit and grounds are all new.
HTH
Old Feb 20, 2003 | 12:42 AM
Redliner's Avatar
Car: Tahoe
anyone put it into a factory wired car
what color are the wires?
Old Feb 20, 2003 | 12:59 AM
viperwsu's Avatar
Car: 91 Camaro RS
I did a swap from an auto, so I mounted the SGI-5 box just to the right of the auto shift-cable hole. I used the rubber grommet from the shift cable to close that hole, and ran the speedo wires through it.
The only wire I tapped into was the radio's power wire. The only other wires are gound (I attached b/t the rubber boot and the tunnel), and the speedo wires to the ecm, and from the tranny. My backup light wires go through that hole too, but those aren't connected to the speedo. All I have to to is take of the shift plate to change calibrations, or get a long skinny screwdriver, and go through the ash tray.
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Thirdgen89GTA
Aug 25, 2015 06:40 PM
JFry
Aug 19, 2015 01:25 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
