Autometer Speedometer T-56
Old Feb 18, 2003 | 10:52 PM
camaro3's Avatar
Car: 88 IROC-Z
Engine: none
Transmission: none
I am going to be doing the T-56 conversion soon on my 88 IROC-Z. I am getting the tranny out of a 95 Camaro. Anyways, i was reading somewhere you have to buy some special box, in order to get the speedometer to work? If I buy The Autometer Speedometer Electric version, will i still need to buy this thing? Or is that if you plan on using the stock dash?
Old Feb 19, 2003 | 10:53 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
im having the same problem. the t56 has an electric output whereas the IROC will have an analog (mechanical driven) speedo. if you get the electronic speedo , it should work but i believe it will be inaccurate, i think you need to get a product from Dakota Digital to make it accurate. this is my understanding of it all. hope it helps somewhat.
Old Feb 19, 2003 | 09:28 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
From what I remember, the T-56 transmits a VVS signal, which the auto meter speedo will work with. So you will not need the Dakota Digital box.
This is the box you were refering to. http://www.dakotadigital.com/Detail....rtNumber=SGI-5
Old Feb 20, 2003 | 03:32 AM
CustomCarShop's Avatar
Yeh, you shouldnt need the Dakota Digital Box.
It would be the exact same thing as hooking it up in the 95 camaro you are getting the tranmission from? It shoudl work on the Electric Autometer Gauge...
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
tonys91rs
Oct 10, 2015 03:31 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
