700-R4 Overdrive problems
Old Feb 20, 2003 | 03:02 PM
xpimpitox's Avatar
Car: 86 IROC-Z
Engine: LG4
Transmission: 700R-4
Drivin on the freeway yesterday i noticed my OD gear is actin up. it feels as if its strugglin 2 shift into gears and it it shifts very high at almost 35rpm. Any possible solutions to this problem? thanx in advance
Old Feb 21, 2003 | 03:31 AM
zerotosixtyV8's Avatar
Car: Camaro
had a similar problem happen to me. It was the 3-4 clutch pack going out. It'd feel as if it were slipping and gripping, higher than normal RPMs, then it just couldn't grip anymore and slid into neutral. COuld only drive it in second gear.
Old Feb 21, 2003 | 12:29 PM
xpimpitox's Avatar
Car: 86 IROC-Z
Engine: LG4
How would I go about fixin this problem and aprrox. cost? i dont know jack **** about trannys so im in the dark. I need my OD gear i make frequent 100 mile trips 2 visit family and such in my car so OD is a good gas saver.
Old Feb 21, 2003 | 12:54 PM
Car: Camaro
Your tranny will need a soft rebuild. Check around tranny shops and ask how much it will be. I personally, used it as an opportunity (more like excuse) to get a performance transmission. I will be needing one anyways with the build up I've got planned. They run upwards of 1000 bucks but can handle 500+ HP. Cheaper would be a rebuild.
Old Feb 21, 2003 | 12:59 PM
xpimpitox's Avatar
Car: 86 IROC-Z
Engine: LG4
I got a daily driver here so i dont want 500+ horses under the hood just yet. not until i get a new car this badboy becuz the ultimate **** and stang burner. i think the soft rebuild would do fine for now. my tranny has about 88,000 miles on it like the car so i think it will be all good
Old Feb 21, 2003 | 01:15 PM
Car: Camaro
yeah, if performance isn't in mind yet, get the soft rebuild. stock can handle up to 300 HP too. It is a common problem for the TH700r4 to have the 3-4 gear clutches fail. They should've given us bullet proof TH200-4Rs but oh well
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
84 TA NV
Sep 6, 2015 08:02 PM
andy74
Sep 3, 2015 08:41 AM
