Tranny Leak Need Help Quick. Loosing Special Fluid
Old Feb 22, 2003 | 04:53 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I just started adding fluid to my New Pro-built Tranny and I have a leak, but its not coming from the pan. From what I can see its from the TV Cable area, I let the tranny down as far as possible but cannot pinpoint location, but like I said its building up behind the backside of the TV Cable. I have tighten down on the one screw that hooks the TV cable to the tranny and its still leaking most of all im loosing my Pro-Built fluid. Can somebody give me any suggestion on how to stop this leak? I DO NOT think it has anything to do with PRO-Built Transmission. Just want to make that CLEAR. Maybe there is a gasket that goes under the TV Cable to Tranny or I should have put some permatex to help keep the seal. Need help Quick.
Thanks: David
Old Feb 22, 2003 | 05:07 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
since your in a hurry- my th350 did that. it was the filler tube it neededa newrubber and the kickdown needed an o ring. drain your fluid and check them before you make abig mess like i did.
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it would help to know what kind of tranny your refering to.. have you checked the gasket around your filler tube? cooler lines?
Old Feb 22, 2003 | 05:13 PM
DTL504's Avatar
Its a 700R4, its not leaking from the filler tube or cooler lines. Its coming from TV Cable area. Maybe its missing the o-ring I will have to take it loose and see. Rest assure it not the cooling lines or Filler tube.
Old Feb 22, 2003 | 09:02 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
There is a rubber seal that goes around the TV Cable housing. Its possible that it got damaged when you installed the TV Cable.
Old Feb 22, 2003 | 11:22 PM
cashman's Avatar
most likely its missing oring, my th350 leaked like a siv after i did the swap, dropped it, looked at the tv cable and it didnt have an oring, put an oring on, its as water tight as a frogs *** now
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
IROCZ1989
Sep 4, 2015 11:54 AM
