My tranny shifts kinda hard??
Old Mar 3, 2003 | 09:13 PM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
I have the 700r4 automatic in there and when i shift from P to overdrive the car jumps...if i shift from P to reverse it jumps...while driving it shifts really hard from first to second and third and forth arent that bad...just kinda jerks the car forward...what are some probably causes for this?
Old Mar 6, 2003 | 01:42 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Mine did the same thing last year. I changed the fluid, filter and gasket and it's been fine ever since. Try that first. Clean the pan good and check for any metal shavings. A little dark sludge is normal from clutch wear. About 4-5 qts should refill it.
Old Mar 6, 2003 | 10:41 AM
jdrafke's Avatar
hmm
Check the throttle valve cable see if it has come undone or broke. If so thats what happened to my car sounds almost the same
Old Mar 6, 2003 | 02:09 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Check the idle if the RPM is too high it will do that, 800 is what its supposed to be. Also might wanna check that mount.
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
TheTraut88
Sep 7, 2015 05:22 PM
Stryker412
Sep 7, 2015 09:11 AM
IROCZ1989
Sep 4, 2015 11:54 AM
