87 trans am 700r4 -speedo sensor on rear
Old Mar 12, 2003 | 02:48 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
i have a 700r4 trans in my 73 vette from a 87 trans am,im trying to get the vss working right,it doesn t have a mechanical speedo housing it has an electronic one with a 2 wire plug on it.What i did was i got a vss buffer module and ran the yellow and purple from the plug to the buffer 1 hot 1 ground and the brown wire from the ecm to the buffer.I dont think its working right,when i come up to hard stop it trys to stall.What i want to do is get my mechanical speedo to work and get the vss working,so should i get the vss adapter from painless or summit ?And if i do ,do i still need the buffer,also its a maf tpi setup.anyhelp would be appreciated i did a search but couldnt find anything that pertained.thanks
Old Mar 12, 2003 | 05:26 PM
jasonbennett's Avatar
get the adapter from summit. it should straighten things out.
Old Mar 12, 2003 | 05:45 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
thanks ill order it now.
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
