9 bolt question
Old Mar 16, 2003 | 05:38 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
9 bolt question
how many of u guys with 9 bolts have a clunk when u put it in gear like reverse then into drive ? and i know its not the u joints.
Old Mar 17, 2003 | 12:11 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I used to have one. It wasn't my rearend...it was my torque arm bushing. Replaced it with an ES piece and it took care of it. Odds are yours is worn out too.
HTH..Ed
Old Mar 17, 2003 | 12:25 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
mines a brand new energy suspension torque arm mount and energy suspension tranny mount.
Old Mar 17, 2003 | 01:15 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Mine does that too but it can be a good thing. The owner before me did a performance rebuild on the transmission which makes the shifts a lot harder. It also gives a nice big jolt when you put it in gear. Does your transmission have a performance rebuild or a shift kit? This will cause this to happen.
Old Mar 17, 2003 | 01:45 AM
ausrs's Avatar
had the same problem with my car
turned out it was the lower control arm bushes
Old Mar 17, 2003 | 11:56 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
hmm, the lca bushings make sense, i didnt use my original lcas either, i used the ones that came with the tranny. i was thinkin it could be the spider gears, cause if u get the posi to break free and wheel the wheels around in opposite directions its notchy but that could just be the way it is?
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
