Stock posi not working - next step?
Old Mar 19, 2003 | 11:16 AM
Dr G's Avatar
Guys:
My stock posi unit appears to have expired! I used to be able to leave two lovely long black tire marks and now I'm experiencing the old "one wheel peel" and am finding it so hard to get off the line quickly.
What should I do now? Should I rebuild the existing unit or get an aftermarket replacement?
If I'm getting an aftermarket one what do you think of the Eaton unit?
Is there anything else I should replace or check when doing all this?
Thanks for your help guys!
Gordon
Old Mar 19, 2003 | 03:15 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Do a search on zexel and eaton in this fourm and you will get all the info you need.
Old Mar 19, 2003 | 04:25 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Also find out if you have a 9-bolt or a 10-bolt Rear Axle Assy. Required Info before spending money or searching for parts.
Old Mar 20, 2003 | 08:29 AM
Dr G's Avatar
The car is a 1989 TA GTA with 3.23 gears.
Will I have a 9 or 10 bolt rear? How do you find out?
Thanks again.
Old Mar 20, 2003 | 08:39 AM
DJP87Z28's Avatar
Check your RPO codes for the Rear Axle stating with the letter ( G)
And G-80 for the Limited Slip. You also can count the Bolts on the rear axle cover 9=9-bolt & 10=10-bolt. Alsio how do you know you have a 3:23 ratio??? Also what engine & transmission do you have???
Old Mar 20, 2003 | 09:39 AM
Dr G's Avatar
I'm at work right now but I'll check the RPO codes when I get home.
I didn't realise checking it was as easy as looking at the rear axle cover!
It's a 350 TPI and TH-700-R4.
Old Mar 20, 2003 | 11:15 AM
DJP87Z28's Avatar
Possible codes for your info....1989 TA 350TPI & 700R4 could be:
GH3= BW 9-bolt 2:77 standard
GW6=BW 9-bolt 3:27 optional
G80 =Limited Slip (Posi)
Least possible:
6HQ/6HJ=10-bolt 3:23
Best guess would be a 9-bolt rear which would leave you with the least options for replacement parts. You could do a search on 9-bolt parts if that is the case.
Old Mar 20, 2003 | 02:06 PM
Dr G's Avatar
Thanks again.
I'll check the codes either tonight or at the weekend and let you guys know so you can give me specific advice re: parts to get.
Old Mar 20, 2003 | 06:12 PM
Dr G's Avatar
I looked at it it tonight - 9 bolts.
Here are some of the codes
G80 : AXLE POSITRACTION, LIMITED SLIP
GW6 : AXLE REAR, 3.27 RATIO
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
JG1 : SHAFT, PROP, ALUMINUM
B2L : PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
L98 : 5.7 LITER V8 TPI ENGINE
Old Mar 20, 2003 | 06:46 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Try
http://www.9bolt.com/
Old Mar 20, 2003 | 06:54 PM
Dr G's Avatar
Thanks Rob:
Any ideas on my options re: the posi?
Gordon
Old Mar 20, 2003 | 08:32 PM
DJP87Z28's Avatar
Well you do have the 9-bolt rear and now the bad news. The parts are very EXPENSIVE for this rear. Try the web site in the previous post and be sitting down when you check the prices.
Old Mar 21, 2003 | 12:01 PM
Dr G's Avatar
Are there any other suppliers of 9-bolt parts I should check out?
Old Mar 21, 2003 | 02:12 PM
DJP87Z28's Avatar
If you can locate one let us know about it.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
marcusaw
Aug 10, 2015 08:13 AM
stalkier
Aug 7, 2015 04:49 AM
