richmond 5 speed or 4thgen 6 speed
Old Mar 26, 2003 | 09:07 PM
zcar8585's Avatar
i need some help here wich would be better for durability gas milage and still have power have alot of low end
P.S how hard is it to make the 6 speed fit in my car will it bolt in
sorry dont know much about trannys
85 z28 w/84 305ho tpi k&n 3.73 gears high flow mass air and mild cam
Old Mar 26, 2003 | 09:22 PM
rjmcgee's Avatar
The Richmond 5 spd doesn't have overdrive, so it would be bad gas consumption. The T56 should be an easy swap with the right pieces. I think you need a new crossmember and have to shorten the torque arm. You could also look into a Tremec 5 spd.
Old Mar 26, 2003 | 09:42 PM
zcar8585's Avatar
i found a tech article on the t56 if i can find one reasonable ill go with that but otherwise the 5 speed thx for the idea with with a tremec too!
Old Mar 28, 2003 | 10:38 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I put a Tremec TKO in mine a couple months ago.
Real happy with it and with the kit from Fortes it was a bolt-in deal.
http://www.fortesparts.com/tremec/tr3550.html
-Rich-
Old Mar 28, 2003 | 07:59 PM
zcar8585's Avatar
how much was the kit for thew bolt in the website didnt say
Old Mar 29, 2003 | 07:09 AM
Car: 92 Camaro RS
Fortes TKO Kit includes: Bellhousing adapter (uses T5 bellhousing), Crossmember spacers, Adapter U-joint, Electronic Speedo Adapter (for whatever rearend gear ratio you have), Backup Light Switch, Shifter (w/o Stick) and 3 Quarts of GM Synchromesh Fluid for about $2200 including shipping.
Not cheap, but will hold up to lots of power and torque.
Tremec 3550 is a couple hundred less, but is rated at less torque.
-Rich-
Old Apr 4, 2003 | 11:36 PM
zcar8585's Avatar
if i buy just the tremec or richmond can i use parts off my t5 to get it to bolt in or do i NEED the kit
Elephantismo
Feb 13, 2019 12:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
