4 cyl posi
Car: 4
Engine: 6
Transmission: 5
Hard to say.... I guess that would depend on whether either of the people that have one would want to part with it... last I heard, they both still liked their cars
i was just wondering if i would get told that it did or didnt exist cause i already have one in the black car that me and firechicken went in on for $75. he got all of the 5 spd stuff, and i got the rest of the car. found out yesterday it already had a limited slip, with the tag and all. firechicken was pissed
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
Well GM did make over couple hundred thousand of the Four Bangers. They were a Cheap entry level grocery getter car.
So I would think the attrition rate would have been high over the years but they exisit and use the same 10-bolt rear axle as most 3rd Gen models. I would also guess they seen less abuse then others also.
quote fromdjp87z28: So I would think the attrition rate would have been high over the years but they exisit and use the same 10-bolt rear axle as most 3rd Gen models
what do you mean most 3rd gen models? the ten bolt was the same as the ten bolt used in any other 3rd gen just minor differences between mine and say an iroc rearend with discs. i realize the nine bolt was an option, but there are far more ten bolts out there that are all the same in our cars (except the disc rears as mentioned before)
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
As far as I know 4 cylinders came with Limited only.....I could be wrong. Ive never heard otherwise.
For your info a Limited Slip and Posi are thr SAME THING....GM uses the word Positraction (aka Posi) as there name for a Limited Slip Axle.
Since they are the same thing they would cost the same to rebuild if it was possible.
I always new it as a limited slip was a rear that only had one wheel spin and posi was both wheels would lock and be used for traction.
If your right what is the "one wheel" wonder termed?
My bro has a limited slip in his 84 camaro and can only burn out one tire...passenger side.
His 88 IROC put a patch down with both tires and his codes say posi....
I am throughoughly confussed.
Why ??? Was the previous Post to hard to understand.
LIMITED SLIP an POSITRACTION (aka POSI) ARE THE SAME IDENTICAL THING.
The RPO code is G80 and states LIMITED SLIP Rear not Posi.....
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Posi-traction was just one of the fancy names to come out of the sixties for Limited-slip. Others were Sure-trac, True-trac..the list goes on.
Even into the 90s American car companies were using different names for limited slip axles. My Jeep has a "Trac-Loc" Dana 35C; but it's really just a limited-slip axle (it doesn't lock the axles and says right on the axle "use limited-slip type lube only")
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
A posi uses clutch packs inside of it. It could be that they are worn, the oil additive isn't in or I have also read they lose tension, and I forget the procedure... it was in a Hot Rod article in the mid or late 90's... i'll have to look.
Car: 1986 Firebird
Engine: 2.8 V6
I hate those Subaru commercials... "Transfers power from the wheels that slip, to the wheels that grip." Damn, I want to punch the announcer in the nose every time; he sounds so smug when he says it.
ANYway, only 4cyl's with manual trannies got the 3.73/open/drum rear. You can also find the 3.73/open/drum rear underneath an '84 Camaro H.O. 3.73 stopped after '85 was over. In fact the last year for the I-4 was '85.
I guess you could call an open diff an "ultimate slip", considering it's not a limited slip
Car: 4
Engine: 6
Transmission: 5
I personally have never seen a rear out of a 4- or 6-cyl F car with Limited Slip, posi, or whatever else you want to call it. All I've seen have been regular open diffs. But there might be a couple of them out there, by accident if not by design, who knows.
Rare LSD sighting in a U-Pull-It yard...
In today's Junk Yard Adventures:
I ran across a TPI 87 T/A that was coded with a 2.73 and Limited slip.... but guess what i saw when I looked underneath. If you guessed missing axles and guts, you guessed right. The TPI motor was gone too. I got the center panel between the tail lights off of it.... everyhting else was pretty well trashed.
But I did get the all of the "collision replacement" parts I needed off of a decent looking 91 V6 bird. Now I truly am a ******* with my maroon hood, bumper and fender. Guess it's time to get to BodyWork 101 class :-)
for all those who say a limited slip was never put behind a four or six cylinder, i started this post because i have a four banger car with limited slip, and wanted to know how common or uncommon it was. so lets not say it didnt come like that. and some other people who have replied to this post have the 4 cyl 5spd with 3.73 limited slip. so for the record they are out there, just seems like kind of a rarety.
Car: 4
Engine: 6
Transmission: 5
It's also possible that a previous owner swapped one in, again possibly even by accident.... they need a rear end for whatever reason, go to the boneyard and order one for a Camaro or Bird, and end up with a posi.
But I think you about summed it up, it's a rarity no matter how it came about.
KO1
16
Oct 15, 2015 05:00 PM
