need help from tranny gear heads!
Old Apr 5, 2003 | 11:47 PM
Opha's Avatar
ok, for all you tranny gurus (sp?) what are the weak parts of the TH-350 and what do you recomend changing out of it for a better or more reliable part. I have been told to put in more clutch packs for a firmer shift. What else should be replaced for a high performance part so the transmission can take more power and last alot longer. This will be the same transmission i will have when i get my engine done, so it will need to handle alot of power and last a while. I also plan on having it refreshed every year to not wear it out so much. Thinking of maybe a tranny cooler to help out on the long term effects. If you can, please put a recomendation on to what would be better vs. the weak parts.
Thanks.
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
crazynights
Aug 21, 2015 06:53 AM
drathaar907
Aug 6, 2015 04:20 PM
