T-56 flywheel
Old Apr 8, 2003 | 02:37 PM
ta350400's Avatar
T-56 flywheel
I am in the process of putting in a T-56 from a T-5. First, can i reuse my T-5 flywheel? Second, Can i use the T-5 starter, or do i have to buy a 4th gen starter? Thanks!
Old Apr 8, 2003 | 03:26 PM
kevinc's Avatar
Car: 1982 Z28
Can't reuse the T5 flywheel (clutch diameter too small) but the T5 starter reports to fit fine.
Old Apr 8, 2003 | 06:24 PM
Mark W. Winning's Avatar
If the starter has the big heavy shrouded nose, it may not work. You can then either use the LT1 starter or a vette starter.
Noting from your t-5 will work, not the crossmember, not the flywheel and not the clutch cylinders either.
Mark
Old Apr 8, 2003 | 07:32 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
You can use a T5 clutch and flywheel from a third gen with the LT1 T56. You just need to get the hydraulic throwout bearing from McLeod that allows this. I have one and am installing this soon. And I'm using a T5 master cylinder.
Matthew
Old Apr 17, 2003 | 05:27 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Hove you done the swap yet? If so How did it work out?
Old Apr 17, 2003 | 05:29 PM
jmd's Avatar
jmd
Not yet. Had to replace the tranny in my other car, and do some other projects
Old Apr 17, 2003 | 06:00 PM
kevinc's Avatar
Car: 1982 Z28
And on the other hand, I've actually done the stuff I recommended and know it works, as well as holding up to abuse...
Old Apr 17, 2003 | 06:07 PM
jmd's Avatar
jmd
Cute flame Kevin. How many T56 swaps did you say you'd done? Don't be jealous of those who don't fear to tread.
I guess I'll go take pics of the T5 before I ship it out. Right next to the T56.
Old Apr 18, 2003 | 06:38 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
from what I have seen so far the t-56 anf the t-5 have the same input. so why wouldn't they use the same clutch/flywheel? I can understand the t-56 having a factory 11" clutch but it should work with a 10.4" clutch too.
Old Apr 18, 2003 | 11:12 AM
jmd's Avatar
jmd
The LT1 production T56 and the 305 T5 have the same length input; it just happens to be shrouded looking in the T56 because the front plate of the case is thick but this doesn't change the amt. of room for the throwout bearing.
Also, the LT1 disc is also 10.4" or 10.5" (note that it's on a 153 tooth wheel, 11" clutches traditionally come on 168 wheels,) however the splines in the hub of the disc are reversed (slight taper,) and the springs might be which is why a T5 disc can't be just reversed and used with an LT1 flywheel even though they look the same.
That's why what I am doing will work.
-Matthew
Old Apr 18, 2003 | 11:50 AM
kevinc's Avatar
Car: 1982 Z28
I didn't say, but sounds like my two swaps and the two years of road and on-track use amounts to 100% more than you.
Don't be jealous of those who don't fear to tread. I guess I'll go take pics of the T5 before I ship it out. Right next to the T56.
I'm not picking on you for experimenting, I'm doing it for you recommending parts you have neither installed nor tested.
I only recommend what I know works. I've done two swaps, both of which see hard track use. If your smaller diameter clutch holds up to abuse and ~ 1 hp/cube input, then good for you and by all means share the data.
Old Apr 18, 2003 | 11:56 AM
jmd's Avatar
jmd
You still don't know the diameter of your clutch.
The Tremec box I built is going 13.5 uncorrected at 5800 ft.
the LT1 trans. that went into Chris's 91 Z will see a 355 with at least a 175 shot in about 45 days. It already saw the same, but on a lesser shortblock.
-Matthew
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tonys91rs
Oct 10, 2015 03:31 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
