Carrier ID needed
Old Apr 13, 2003 | 01:27 AM
vwdave's Avatar
Carrier ID needed
Ok, I bought a 2.73 posi/disc 7.5" 10-bolt setup for my Camaro. I am not 100% sure what series carrier it has in it. (Before anyone calls me a idiot and says "its a 2-series dumbass" the gears are not stock.)
Hell, I dont know what type of posi it has. It chirps around corners some, and has almost no slip, I am thinking it might be a locker, so, I am going to pull the cover tommorow and look. Is there any way I can see what series carrier it has?
The reason I want to know, is I want my old 3.42 gears back on there, I need to know if I should buy some gears, or re-use my old ones.
Old Apr 13, 2003 | 02:01 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
it's a 2-seriesunless you find a spacer in it when you take it apart, there are spacers to put 3-series carriers in 2series rears...i doubt you have one tho, and the new gears mean nothing, you have to buy them specific to the carrier type they're going into...hth
elmo
Old Apr 13, 2003 | 02:17 AM
vwdave's Avatar
Ehh, what the hell, I'll give it a shot. Whats the worse that can happen? I blow the rear to hell and gone?
My friend is giving me a Moser 12-bolt if I manage to blow this rearend up.
I know, I know "Why dont you just put the moser in now?"
Hell if I know. I think he wants to see me blow the rearend he couldn't kill. *Shrug*
Old Apr 13, 2003 | 07:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well you can't put 2-series gears on a 3-series carrier; since there's no spacer made that takes space or metal away. So if it has 2.73 gears in it, it's a 2-series carrier. Believe that.
Beyond that, take the cover off and look. We could all speculate endlessly about what sort of posi / spool / locker it does or doesn't have, but htat won't have the slightest exxect on what's actually in the housing.
Your 3.42s will not go on that carrier, unless you use a spacer.
Old Apr 13, 2003 | 09:44 AM
vwdave's Avatar
I am taking the cover off today, I just needed to know how to tell what it is by looking.
hectre13
Dec 11, 2023 08:14 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
