manual tranny fluid?
Car: 1990 rs, pride and joy
Engine: 305 tbi
Transmission: t-5
Okay it says in my chilton to use DexronII automatic fluid for my 5 speed, but it also says to use 80w-90 fluid also? just a bit confused
got a 90 rs if that helps
got a 90 rs if that helps Member
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
You would use dexron III in a 90 rs. Some of the older cars specified gear lube. I used redline MTL in my 91 Z when I was running my T5.
