3rd gen rear wheel size?
Old Apr 16, 2003 | 08:07 PM
Tailmaphas's Avatar
Car: 87 Pontiac Trans Am GTA
Engine: tpi 355
Transmission: t56 6 speed manual
Axle/Gears: 9 bolt 3.90
Anyone out there know just how big a wheel (rim) you can fit on an 84 T/A with stock ride height and rear end assy? Will a 15x10 with 5" backspacing fit with say a 295/50/15 tire? If 15x10 will not fit, what is suggested backspacing on a 15x8 wheel?
Old Apr 16, 2003 | 10:29 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
I dont beleive that you can fit a ten inch wheel on it, you can however fit a 9.5 inch 17" wheel, dont know about a 15" wheel, but 9.5 inchs wide is 9.5inchs wide.
screw the 15"s and get some 9.5"X17" with 5.5" backspacing and run a 275/40/17 tire (make sure that front suspension is tight though)
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
